Hi guys,
the side skirt on the jimny has come off. A friend stepped on it while getting out and it has obviously fallen off before and replaced with dodgy panel pins.
I now have a small problem of finding a set of the correct plastic trim panel pins to attach it back. I tried a few I had but nothing was suitable.
Any ideas what the actual pins are called?
Any help would be greatly appreciated!
Thanks all.
Jimny bodykit panel pin help
Re: Jimny bodykit panel pin help
Trim clips, they are about £4 each!
I've replaced mine with self tapping screws!
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Self tappers the way to go
Give number 16 a Google.
Readily available on fleabay and cheap.
- hjkj.jpg (57.45 KiB) Viewed 5185 times
I tried 16 (part number 09409-07332), they are push pins. They attach the skirt on the underneath. The clips that push into the trim & sill are different from those. I think I may have the right one, found 10 on ebay & with some luck might work!
Will keep the thread updated as to how I do
Thanks for the input.
