As the title states, will these fit & if not how hard is it to make them fit/ do you know any similar that would fit, I'm assuming I'll need a led conversion harness and I think LROR sells one? Also anyone know if they are road legal or not cheers!!
https://www.ebay.co.uk/itm/122706922494
Will these Headlights fit?
- SlimGrim
- Winching along now
- image.jpeg (65.44 KiB) Viewed 5461 times
___________________
Re: Will these Headlights fit?
They should do, but may have some issues when it comes to the not due to the beam pattern.
- SlimGrim
Anyone know how I can fix out the legality of them regarding beam pattern?
___________________
I tilted mine over slightly and they let it go
They should be similar to mine size wise. If you have the headlights that mount in with 3 long screws and springs, you can re-use the old headlight carriers
You will need to set up 2 relays to convert from negative switched headlights to positive switched, but its not difficult
