Page 33 of 36
Re: Tramps Truck,
Posted: Thu Sep 08, 2016 9:54 pm
by ROBBIE
I might have one, if I find it I will pack it with the other bits
Re: Tramps Truck,
Posted: Thu Sep 08, 2016 10:00 pm
by Tramp
If you have Robbie, that would be great!
Re: Tramps Truck,
Posted: Mon Sep 12, 2016 10:27 am
by Tramp
So back to the o ring, the distributer o ring is part number 09280-56004, it is 1.9mm cross section with 55.5 inside diameter measurement, I've just ordered one,
Re: Tramps Truck,
Posted: Mon Sep 12, 2016 2:37 pm
Tramp wrote:So back to the o ring, the distributer o ring is part number 09280-56004, it is 1.9mm cross section with 55.5 inside diameter measurement, I've just ordered one,
I just used hylomar. Worked a treat.
Re: Tramps Truck,
Posted: Wed Sep 28, 2016 11:10 pm
by Tramp
So back on it again, whilst the zook was sat I decided to freshen up the metal surrounds on the high level spot lights,
They were defiantly starting to look scabby, so I whipped them off, blasted them and painted them....
Much better!
Today I also decided to fit my new 90degree adaptor.....
This is my old one
Notice the lack of bolt at the bottom nub,
And my replacement
I tried fitting my shaft and distributer into the new housing but it wouldn't slide in,
I checked and.....
My old
And my replacement,
It looks like my replacement has a smaller hole in the bottom than my original. Did they do different sized distributer shafts? Did it change from 1298cc engine to 1324cc? Or have I got an adaptor from something like a 410?
Re: Tramps Truck,
Posted: Wed Sep 28, 2016 11:47 pm
Could well be off a different engine.
I have loads of these if you want me to send you one?
Re: Tramps Truck,
Posted: Wed Sep 28, 2016 11:54 pm
by Tramp
ScottieJ wrote:Could well be off a different engine.
Yes please Scottie, I'll pm you,
Re: Tramps Truck,
Posted: Thu Sep 29, 2016 7:42 pm
Whats to PM. Just send it here Scottie.
SCUK South Yorkshire
Rotherham (Just off the M18).
It'll get there, honestly.
Re: Tramps Truck,
Posted: Fri Oct 07, 2016 9:43 pm
by Tramp
It made it here fine,
I cleaned it up a bit, & gave it a bit of a polish (oh-er) but I didn't go over the top, it's not like I'll give it any attention when it's fitted,
I lined up my collection of adaptors,
I was going to use the o ring from the adaptor which had the smaller diameter hole, but when I got it out it broke as it had gone brittle. I did order a new o ring but it seemed a little bit small. When the old one broke I was forced to use it, I had to heat it up and pull it a bit to get a t to stay in its groove as it kept trying to roll out.
But then, it all went together
I had to set the timing again but damn, it's good to be back on the road!
Re: Tramps Truck,
Posted: Fri Oct 07, 2016 9:48 pm
by ROBBIE
Nice, glad it's all sorted and back on the road :thumbup:
