First clean
Posted: Sat Jul 08, 2017 8:55 pm
Ha ha yeah the guy did say you looked at it and said it wasn't in bad nick. I'm also in Norwich near Snetterton race track just off the A11.SlimGrim wrote: Damn! I knew I should have bought it haha!
Glad it went to someone who's giving it the love they need
I'm just outside of norwich so give us a shout if you ever need someone to go offroading with
Nothing major really just to keep it in good working order to use everyday. I'm thinking of getting a Weber carb but the standard one seems to be ok apart from cold starting which takes a lot if cranking. I'm happy with how it looks so just tidying it up.zook123 wrote:What other plans do you have for her?
Sounds very similar to the Subaru / Daihatsu / Hyundai carb swaps i have done in the past.SlimGrim wrote:Literally just done a Toyota 3k carb swap on it tonight after putting in like 3 weeks of research and basically it's just a straight swap haha, you'll need your own bolts to bolt it on as the old sj ones go all the way through the old carb block, also need to loop the water lines from the water choke back on itself, plug two vacuums and just a bit of tuning, the throttle pulley bracket will also need to be bent down and adjusted as the sj throttle cable is a tad long and comes lower down on the toy carb, many guides mentioned filling in a vacuum channel and filing in a new one, I haven't so far and haven't seen any negatives or positives of not doing so, runs a heck of a lot better than the old Aisin, I'll post a guide on what I did soon with loads of pics! Ah nice I'm actually residing in long stratton so not too far, if you need a hand with anything I'm more than happy to help!
That sounds pretty good! I'd be interested to know what the mpg is like. I'm getting about 30mpg which I didn't think was bad. Get a guide up . Not too far then so I'll deffo let you know .SlimGrim wrote:Literally just done a Toyota 3k carb swap on it tonight after putting in like 3 weeks of research and basically it's just a straight swap haha, you'll need your own bolts to bolt it on as the old sj ones go all the way through the old carb block, also need to loop the water lines from the water choke back on itself, plug two vacuums and just a bit of tuning, the throttle pulley bracket will also need to be bent down and adjusted as the sj throttle cable is a tad long and comes lower down on the toy carb, many guides mentioned filling in a vacuum channel and filing in a new one, I haven't so far and haven't seen any negatives or positives of not doing so, runs a heck of a lot better than the old Aisin, I'll post a guide on what I did soon with loads of pics! Ah nice I'm actually residing in long stratton so not too far, if you need a hand with anything I'm more than happy to help!
