Page 10 of 13
Re: 1991 Santana Samurai
Posted: Sun Mar 31, 2024 8:47 am
by tomcat
Thank you. Not sure how I missed that in my search on the internet. Should have gone to Specsavers maybe
Posted: Tue Apr 02, 2024 11:31 am
by tomcat
OK today Samurai steering box removed to fit early Jimny box [part number 48600-81A20]. Jimny box will not fit without some spacers as it fouls the chassis member. Is this usual?
Posted: Tue Apr 02, 2024 12:18 pm
The body needs a small amount of clearancing but it just bolts straight onto the chassis.
Don’t forget you also need to shorten the steering column, you will need a press.
Posted: Tue Apr 02, 2024 12:19 pm
by tomcat
Before transfer box got refitted carried out Scottie's breather upgrade.
Posted: Wed Apr 03, 2024 2:12 pm
by tomcat
ScottieJ wrote: ↑Tue Apr 02, 2024 12:18 pm
More effort and the steering box did fit fine.
Yes aware column needs shortening. Getting assistance with that. Thanks.
Posted: Thu Apr 04, 2024 10:05 am
by tomcat
Package arrived yesterday bringing me my "alternative" power steering option. A Volvo electric pump.
Will look at trial fitting of this and then decide whether it is 'hydraulic' or 'electric / hydraulic' I decide to use.
Posted: Fri Apr 05, 2024 2:51 pm
by tomcat
Intend to spend time over the weekend positioning items such as auxiliary fusebox, relay location, oil catch tank etc.
Do trial layout of wiring within engine bay. Will keep me out of mischief, weather permitting!!
Posted: Sat Apr 06, 2024 2:44 pm
by tomcat
Some positive activity today. Decided to go with the Volvo electric power steering system with an oil cooler behind the radiator.
Had purchased some connectors for the heavy duty cables which I fitted. Will be using an 80amp breaker in the circuit.
Fitted a connector to the existing grey/blue wire on the pump which I will feed from the ignition block.
Posted: Sat Apr 06, 2024 3:04 pm
by tomcat
Bit more wiring done. New cable to starter. 50amp breaker connected into loom, replacing the previous owners 'modification', connection to battery prepared but not fitted as yet. Ignition block in place.
Posted: Sun Apr 07, 2024 10:52 am
by tomcat
80 amp circuit breaker and oil catch tank positioned.
Before anyone asks the question a blue tank was delivered. Red would have been preferred.
