Bracket fitting to Engine block
Posted: Fri Mar 22, 2024 4:01 pm
by tomcat
I am seeking the thread of the M10 bolts to fit a Jimny power steering arrangement to the G13A engine block on my Samurai please.
It does not appear to be M10x1.25.
Any assistance appreciated. Thanks.
Re: Bracket fitting to Engine block
Posted: Fri Mar 22, 2024 7:04 pm
It should be M10x1.25 Unless someone has messed the threads up.
The threads might just need chasing with a Tap.
Posted: Fri Mar 22, 2024 9:06 pm
by tomcat
Thank you. Will follow your suggestion.
Posted: Mon Apr 08, 2024 6:21 pm
by Brady
If M10x1.25 doesn't seem to be the right fit, it's possible that you might need a different thread size. You could try checking the threading of the existing bolts or consulting a mechanic or hardware store for assistance.
Alternatively, you might want to look into getting a thread gauge to accurately determine the correct thread size needed for your application. Once you have the correct thread size, finding the appropriate bolts should be much easier.
Posted: Tue Apr 09, 2024 6:42 am
by tomcat
Thank you for your message. Your comments noted and appreciated.
