Page 1 of 2
UJ Info
Posted: Thu May 06, 2010 1:03 pm
UJs
84 Onwards Jap built 25.00x63.80
code= PUJ2028
Hardy Spicer greasable UJs HS157
Also found these codes but need to confirm they are correct
TOYO RUJ1783 with external circlips, or RUJ1795 with internal circlips.
KOYO (Suzuki use Koyo) with External circlip is RC1518-CC1A, Internal type is RC1518-RCC
Re: UJ Info
Posted: Fri Oct 17, 2014 2:04 pm
Just had a mare of a time finding Samurai UJs.
Ended up getting them from BRT Bearings. If anyone needs the code number: PUJ2028
Re: UJ Info
Posted: Fri Oct 17, 2014 3:48 pm
twiss wrote:Just had a mare of a time finding Samurai UJs.
You mean that code at the start of the this thread :tongue:
Re: UJ Info
Posted: Fri Oct 17, 2014 3:56 pm
hahah yes indeed i do
Re: UJ Info
Posted: Thu Jan 22, 2015 12:59 pm
by rundo
Hi guys,
as I understand ALL UJs ARE THE SAME right? Regardless which shaft?
Guy from part place trying to tell me that UJs on first shaft (trans to tbox) is smaller than the rest, like 24 x something..?
Re: UJ Info
Posted: Thu Jan 22, 2015 1:08 pm
It shouldn't be but there are a few late model and aftermarket props around that use a UJ with a 24mm cap.
Re: UJ Info
Posted: Thu Jan 22, 2015 1:56 pm
by rundo
OK I will measure it then just to make sure.
THNX
Re: UJ Info
Posted: Fri Jan 23, 2015 3:38 pm
Don't get GMC brand ujs they are crap lol
Re: UJ Info
Posted: Wed Jun 05, 2019 7:54 am
by marve114
What’s the best uj to get them lads ?
Re: UJ Info
Posted: Wed Jun 05, 2019 9:38 am
by timwilks13
Ideally KOYO are the best but they're no longer in the automotive market so nigh on impossible to get hold of. I recently fitted a Blueprint UJ and it lasted about 900 miles so avoid, I then ordered some Stark ones but when they arrived they felt like chocolate so sent them back without even fitting. I currently have Matsuba but the car hasn't moved since I fitted them so can't confirm if they're any good, but they felt good quality and they're Japanese which is usually a good sign!
