ARB not switching off
bingen
Post by bingen » Fri Aug 12, 2011 11:54 am
When I switch the pump on for my arb locker, it usually runs for a few seconds and then when I switch the locker on, the pump would go for a couple seconds until the unit is engaged.
Now, the pump still does the same thing, but when the rear locker (I only have the one) is engaged, the pump no longer switches off after a couple seconds and it just keeps going.....
So what gives?...is this normal?....you think there's a leak?...
'11 Jimny 235/75R15 mud terrains, auto trans, ARB rr locker, ARB winch bumper (winch to come) and 2.5" OME lift.
'84 SJ410 31" MUD tires, 5 speed, A/C, 4.1 gears (sold) (open),
Re: ARB not switching off
Post by Edweird » Fri Aug 12, 2011 12:26 pm
Sounds like a probable cause. That's what my compressor did when a hose split.
Post by twiss » Fri Aug 12, 2011 2:22 pm
Yeah sounds like a split hose to me as well...
That's why I think I like electric lockers instead... then it's only a bit of wire ;)
rockwatt
Recommended Trader
Recommended Trader
Post by rockwatt » Fri Aug 12, 2011 3:05 pm
Yep damaged air line! Or not enough oil in the axle.. The o rings in the arb slip ring need oil to completely seal! If the level is low then they will pass.
Rocklobster gears , refurb cases , dual cases , su manifolds , jimny rocklobster conversions inc speedo drive, t/case heavy duty mounting arms and rock buckets, bespoke fabrications and machining,
Contact me for details.
bingen
Post by bingen » Sat Nov 12, 2011 8:13 am
thanks all, got it fixed. Twas a leak at the coupler near the diff...i guess it must've gotten caught on some debris. tied it up with some zip tie to the frame.
