SuzukiClubUK
The complete resource for all your Suzuki SJ needs
It is currently Wed Sep 08, 2010 10:28 am
SuzukiClubUK needs your help and support in order to keep this site running.
You can make a quick and simple voluntary payment by credit card, debit card or your PayPal account.
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
Author Message
 Post subject: Re: disc handbrake
PostPosted: Tue Feb 09, 2010 7:57 am
Offline
SCUK regular
Check my last post??? i didnt read it all!!!..
you may have to hire, beg steel etc a puller. that what i used to remove my flanges so i could strip my transfer box..
Top
 Profile
PostPosted: Tue Feb 09, 2010 9:31 am
Offline
SCUK regular
ahh well i will try removing it with the prop shaft first! i have a selection of pully pullers but not sure if the biggest one is big enough!
Top
 Profile
PostPosted: Tue Feb 09, 2010 4:52 pm
Offline
SCUK regular
on the rear of the backplate, there are two nuts and opposite two bolts, these hold the adjuster in situ. unbolt these and callapes the brakes??. but i reccon its the drum tight on the splines..
Top
 Profile
PostPosted: Tue Feb 09, 2010 5:17 pm
Offline
SCUK regular
yeah i think its just the drum ceased onto the splines! was suppose to do it today but it took me 4 hours to get a half shaft out my rear axle as the bearing was completely ceased! i had to make a slide hammer out of an old steering arm and a pair of bike handle bars :lol: after all that it wouldnt budge! i was going to try and yank it out with my range rover but thought it might be overkill :| ended up turning the drum around getting a crowbar about as long as the River Thames on one side then hitting with a sledge hammer the otherside! almost fell of its axle stands the poor thing haha :P.
i will have a look at the handbrake tomorrow when i get the rear axle back together!
if i cant get the drum off the transfer box i will just leave it and use the hand throttle for hill starts haha :x
Top
 Profile
PostPosted: Tue Feb 09, 2010 5:50 pm
Offline
SCUK regular
if you cant move it, and havnt got the tools.. i would leave the rear prop off, drive to a local garage and get them to put a puller on it,?? might cost you a drink, but its better than wrecking the drum..
Top
 Profile
PostPosted: Tue Feb 09, 2010 6:44 pm
Offline
SCUK regular
id love to do that mate but it has no seats in it and a bit of wiring and my air box needs to be fitted ect also have no insurance yet! i like to do everything myself so if i cant get it off ill leave it for now until i can take it up the yard and get my gas torch on it. cant even bloody tow it up at the moment with no wheels on the back :|
Top
 Profile
PostPosted: Fri Mar 05, 2010 3:46 pm
Offline
SCUK regular
I changed my mind about this X-eng handbrake! it used to work fine but now its doing my nut in after destroying another set of pads and not releasing properly!! I am going to try and modify it to make it work better and if i do i'll post the progress!
_________________
'87 SJ410, 1.6 8v, vit gearbox, dual transfer box set up, 33x12.50s, virtual lift & 2"lift springs, pick up conversion.
PM me for suzuki bits
Top
 Profile
PostPosted: Fri Mar 05, 2010 4:18 pm
Offline
SCUK regular
ive just gone back to the drum handbrake??. i bought two new handbrake cables for my sammy,, £48 so ill be selling them,, reason is im going to rear disc it.
Top
 Profile
PostPosted: Fri Mar 05, 2010 5:11 pm
Offline
SCUK regular
rear disc all the way.. my handbrake hasnt let me down yet :| :lol:
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
