Jordis 1988 Samurai (Re)Build
Post by Jordi » Sun Apr 03, 2022 9:46 am
I’m well chuffed Robbie, revived for another year.
Post by Jordi » Sun May 08, 2022 6:19 pm
Using this as the moment before it’s run out to wiltshire.
Oil, filter and plugs done.
Had oil peeing out of a rear hub, fitted a new seal. Hoping thats sorted it.
Swapped the rear drive flanges to 10.9 bolts, loctite and spring lock washers! Should stop them coming loose
Got a clutch release bearing on the way.
Ordered some spare seals and gonna make up a spare hub to carry with me. Same hubs, brakes and bearings on all 4 corners makes carrying spares so much easier.
Post by Jordi » Sun May 15, 2022 3:51 pm
Fan belt was squeaking. Wasn’t quite as simple a fix as anticipated. The top bolt had sheared. Rad and fan out, drilled out the bolt, which luckily wasn’t seized and just screwed through as i drilled. Which was a bonus.
All back together again.
Post by Jordi » Sun May 15, 2022 3:57 pm
As recommended in another post also ordered this
DNA Motoring HDS-SSAM86 Stainless Steel Exhaust Header Manifold https://www.amazon.co.uk/dp/B074KTB6T2/ ... UTF8&psc=1
The price is slowly going up though. It was £122 a week ago, up to £127 now.
Need to have the tracking looked at i think too.
d_r_1989
Post by d_r_1989 » Sun May 15, 2022 10:09 pm
Looking good. A long way to drive in an sj is Wiltshire!
Post by Jordi » Tue May 17, 2022 11:18 am
Shouldn’t be any worse than 2019s wales trip. Be quieter with the extra silencer 🤣
d_r_1989
Post by d_r_1989 » Tue May 17, 2022 12:30 pm
I wish you could buy a silencer for 33" tyres!
Post by Jordi » Mon May 23, 2022 10:56 am
Swapped a rather rattly clutch release bearing out over the weekend.
Gradually working through the little niggles.
Philpy
Post by Philpy » Mon May 23, 2022 4:48 pm
Manifold looks nice! How does the rest of the system mate up to it?
Post by Jordi » Mon May 23, 2022 5:47 pm
I already have a custom exhaust but not the diameter required.
The new manifold comes with a 2” flange to weld onto the exhaust so i’m going to make a new 2” section that will run underneath behind the chassis then add a 2” to 2.5” adaptor to join it onto the existing stack behind the cab.
