doubts...
Re: doubts...
Post by ROBBIE » Mon Jun 20, 2011 5:11 pm
carnt sell mine couldnt stand the thought of some little oik having my fun
Re: doubts...
Post by twiss » Mon Jun 20, 2011 5:20 pm
Just think... it could end up like one of those battered up SJs the chavs use/smash up at pay and play sites
THE HORROR
Lil_Beastie
Re: doubts...
Post by Lil_Beastie » Mon Jun 20, 2011 6:06 pm
twiss wrote:Just think... it could end up like one of those battered up SJs the chavs use/smash up at pay and play sites
THE HORROR
your not a chav! :lol:
Re: doubts...
Post by turbo-tom » Mon Jun 20, 2011 6:48 pm
THE HORROR
he might drive like one though :P also twiss should know his towing limits :hahaha: :hahaha: , also why do most chavs get tin tops aswell and smash them up :er: :lol:
Re: doubts...
Post by twiss » Mon Jun 20, 2011 11:15 pm
hahaha
its ok to tow an sj to recover it when it's broken/shit tom ;)
if your brakes weren't sticking and an engine lighter than the moon, it would have been much easier!
Besides, my truck has MOT... sometimes ;)
Every broken bit of it has been broken while road legal!
Russ24
Re: doubts...
Post by Russ24 » Mon Jun 20, 2011 11:58 pm
Lil_Beastie wrote:By water getting in through the vent, what do you mean? Have you cleaned out the drainage pipes in the vent under the windscreen?
I think everyone has downers about whether or not to keep theyre SJ at some point (if not often).
erm?
ok. no idea what you speak of.
:russ:
Lil_Beastie
Re: doubts...
Post by Lil_Beastie » Tue Jun 21, 2011 7:10 am
erm?
Wheres the water leak from inside? behind the dash/heater somewhere?
Russ24
Re: doubts...
Post by Russ24 » Tue Jun 21, 2011 10:46 am
erm?
yeah water collecting in plastic pipes.
comes out at bottom of heating system
:russ:
Lil_Beastie
Re: doubts...
Post by Lil_Beastie » Tue Jun 21, 2011 6:26 pm
Right,
You know the grill below the windscreen on the bulk head. Under that is where the heater takes in the air from outside. However it also colects the rain water to stop it going into the system, like it currently is.
The water drains down either end of the plate you can see under the grill. It drains into the engine bay through some plastic pipe that you can see under the bonnet, stick out the bulk head. They will be full of mud.
Youll need hot water, and a thickish (1-2mm dia). Poke the wire round through the grill on top down into the drainage pipe. And up through the pipes coming going into the engine bay.
Keep pouring water into the grill and keep poking around. :poke: Eventually it'll start working its way through.
Russ24
Re: doubts...
Post by Russ24 » Wed Jun 22, 2011 1:29 am
Lil_Beastie wrote:Right,
nice one.
having looked earlier i have seen the mud......
that will contribute to the water seapage..
HOWEVER i have found something more disturbing while looking for these blocked pipes.
corrosion and bubbled paint just below the windscreen below the rubber seal. real bad times. and poking that with wire would be a bad idea. just be where the rest of the water is getting in.
shit
thats quite abit more work.
:russ:
