Tyre question
- donkeychomp
Re: Tyre question
What Vit are you talking about? a GV? There is no way 16's would fit a Vitara with 235's on it unless the previous owner did some serious lift work. 215's are the max for a bog standard Vit, even then they rub a little on full lock. Mine is only raised 2" but she still needs more cutting to get the 29" tyres to articulate properly. My advice is find a standard Vit and park side by side, then you'll know how much your car has been lifted.
Re: Tyre question
yes on my Vit they clear it is standard. will soon be putting GV springs on
2003 GV1600 sport
1995 Vitara SWB
1995 Vitara SWB
Re: Tyre question
235/60R16 is only 27" diameter,donkeychomp wrote:What Vit are you talking about? a GV? There is no way 16's would fit a Vitara with 235's on it unless the previous owner did some serious lift work.
Re: Tyre question
I think 195/80R15's are standard? About the same diameter as the 235/60R16's (actually slightly bigger), but what rims? Perhaps the wheels Donkeychomp is thinking of had different backspacing which made them rub on full lock because it's a much wider tyre?Rhinoman wrote:235/60R16 is only 27" diameter,
Too many unknown variables to say for sure what will and won't rub, I'd say you'd have to suck it and see.
Do people do virtual lifts on Vits?
Re: Tyre question
standard GV steel rims not the ones with the deep dish, the circumference is .66% different.
yet on my GV with a 2" lift if I put 245/70/16 on they rub before they reach full lock :( so these will go in the Vit when lifted and trimmed
2003 GV1600 sport
1995 Vitara SWB
1995 Vitara SWB
- donkeychomp
Re: Tyre question
Yes Anton...the vl has been started on Piglet3. But like most things it isn't finished yet!
Re: Tyre question
I ran 235 KL71's on my Vit, with a 10cm suspension lift. They might work with only 2inches of lift, but some cutting might be required for the front/rear wings. Also mine, with the stock steel rims, were rubbing against the chassis on maximum turn so I fitted wheel spacers.
