Opinions please.. (new light bar)
Re: Opinions please.. (new light bar)
Post by ScottieJ » Thu Sep 28, 2017 4:48 pm
I think i'd just get annoyed with anything mounted to my bonnet :lol:
Post by ROBBIE » Thu Sep 28, 2017 5:26 pm
Was first mounted under the bumper, but got taken off by a stump, so was agreed to go there. Truth is im not a fan of light bars, don't see what's wrong a good pair of spots, but there you go, I only fix things on it
dan00001
Post by dan00001 » Fri Sep 29, 2017 7:36 pm
Well decided it made more sense to mount under the bull bar, and I like it.
Can I wire the switch from the relay directly to my high beam? So the light bar comes on with high beam only?
SherwoodNash
Post by SherwoodNash » Fri Sep 29, 2017 7:49 pm
Vey neat job! :doublethumbs:
Post by ROBBIE » Fri Sep 29, 2017 7:50 pm
Yeah, I had spots wired in that way on the old one
palo123
Post by palo123 » Fri Sep 29, 2017 9:06 pm
i'm not 100% sure but i didn't think you were allowed to use off road lights on the road with your traditional road use lights.
dan00001
Post by dan00001 » Fri Sep 29, 2017 9:09 pm
Thanks Sherwood, I drilled & tapped into the bb, took a while to get everything perfectly lined up so I could drill the holes in the right place but I think she looks good.
Thanks Robbie, going to wire her up tomorrow :)
dan00001
Post by dan00001 » Fri Sep 29, 2017 9:11 pm
palo123 wrote:i'm not 100% sure but i didn't think you were allowed to use off road lights on the road with your traditional road use lights.
I was under the impression that you could use them only on your high beam and they had to be under a certain size to use on the highway?
Post by turbo-tom » Sat Sep 30, 2017 6:00 pm
Looks good however I would move your number plate as your radiator will not get any air flow
Post by Anton » Sat Sep 30, 2017 10:09 pm
I'd assume (so correct me if I'm wrong) that they would need to conform to the beam pattern required by law for a high-beam headlight.
Wire them up through a switch so you can kill them for the MOT and you'll probably be fine. Probably.
Just don't get caught by the DVSA... :doublethumbs:
