why has he done this
Re: why has he done this
I dunnoe, I think the front end on the first one looks like its been done alright. Ive seen worse things.
I might be missing something here, but why is that front clip much wider than the body? doesn't look like he widened it? i'm a little lost on that
He has widened it between the light surround and grill, look where the indicators arekiwizook wrote:I might be missing something here, but why is that front clip much wider than the body? doesn't look like he widened it? i'm a little lost on that
That green one would be really nice without those 'things' on the side, I can appreciate the effort that must have gone into them but the end result is far from aesthetically pleasing
See, its been done soo well kiwizook couldnt even tell:)
Neither are my cup of tea. I much prefer the way most of us have done them with sheet steel or the thick rubber. The front end looks ok on the first on. Its where it steps back at the doors the doesn't look right.
The green one isn't *dire* - it's not great, but it's not as bad as the patchwork one, which is totally minging.
Not sure why he's decided he needs wider axles, deep dish rims *AND* a set of spacers - loose the spacers and a set of normal arch extensions would've been enough.
Probably.
Probably.
- littlesammy
i think they are both on flea bay now or at Least the lime green one was tin other day.!
87 Samurai with added spice !
