Any idea what rims these are?
Re: Any idea what rims these are?
Post by Anton » Tue Apr 21, 2015 9:20 pm
gamble63
Post by gamble63 » Tue Apr 21, 2015 9:26 pm
see on jimny bits it says
"These wheels look great on a Suzuki and the -30 offset is for those who want a wide stance without fitting wheel spacers"
but looking at your image it makes it look like we want a positive offset?
or am i looking at it wrong?
these were some old sj wheels i had and im guessing they are 0 offset
Post by Anton » Tue Apr 21, 2015 9:47 pm
In that image the inside face of the wheel is on the left, the outside face is on the right. So -30 means that the wheels would stick out an extra 30mm further than 0 offset. Similar to getting 30mm spacers.
Bear in mind that if the rims are wider than the ones they replace, then 0 offset rims will stick out a bit further anyway.
gamble63
Post by gamble63 » Tue Apr 21, 2015 10:07 pm
ah that makes sense, thanks Anton, i will measure tomorrow and if all is good will order them :)
hopefully problem solved.
Thanks guys
gamble63
Post by gamble63 » Tue Apr 21, 2015 10:10 pm
lol naturally they only have 1 in stock haha
gamble63
Post by gamble63 » Wed Apr 29, 2015 10:30 pm
Hey guys had a quick measure of the wheels on the truck today, i think i measured it from the right place and was getting 8" width and that i think is a 30mm offset. i know jimny bits sell 7" wide with the 30mm offset but i cant find any 8" wide, if i run with the 7" wheel is that going to be ok with the 31"x10.5x15?
Thanks guys
Post by ScottieJ » Wed Apr 29, 2015 10:43 pm
You measure the wheel width from the inside of the lips so if it's 8" outside edge to outside its gonna be a 7" wheel.
12callum
Post by 12callum » Wed Apr 29, 2015 11:14 pm
Pretty sure I've got a set of 5 of these wheels I'll try and find a photo!
gamble63
Post by gamble63 » Thu Apr 30, 2015 7:12 am
ah thanks Scottie that is great news, Callum im after 2 of them so that would ruin your set of 5. if you do have the same size with the 30mm offset and want to sell 1 id buy one from you and one from jimny bits.
cheers guys
edit** jimny bits are out of stock at the mo, dammit
