Compatible parts list?
Yamasuki
Post by Yamasuki » Sat Nov 05, 2016 2:41 pm
Hello everybody. Im new here and im looking to find a list of vehicles with parts that fit the different sj models if there is one. many thanx
SherwoodNash
Re: Compatible parts list?
Post by SherwoodNash » Sat Nov 05, 2016 2:57 pm
:welcome:
SJ410, SJ413, plus 1.0L engine parts from the Bedford Rascal and Suzuki Carry :er:
Yamasuki
Post by Yamasuki » Sat Nov 05, 2016 4:06 pm
Thankyou, do you by any chance know of different axles that will fit a lwb samurai?
Post by ScottieJ » Sat Nov 05, 2016 4:16 pm
The only direct bolt on axles are samurai axles.
It's possible to make pretty much any axles fit as long as they have the diffs offset to the driver side (right hand drive) if you can weld/fabricate competently.
Unless you want to run 35"+ tyres there's no need to swap axles though.
Yamasuki
Post by Yamasuki » Sat Nov 05, 2016 4:44 pm
Thanx very much. I thought that that might be the case. do the maruti gypsy parts fit sj's?
Post by twiss » Sun Nov 06, 2016 5:55 am
Yes mostly... the mg410 is the same parts as an sj410, the mg410w is the same but has wider axles.
gypsy king shares most parts with samurais
Yamasuki
Post by Yamasuki » Sun Nov 06, 2016 5:22 pm
Ah right excellent, thanx for the info.
